Random Questions
Random Questions
Ive posted a couple of threads but I figure I should just put remaining questions I have in one thread so I dont clog up the boards so please bare with me as a new evo owner lol.
1. Didnt find much on this for a stock evo ix. Does it make much sense for me to get a custom tune instead of a generic flash since my car is 100% stock? Im guessing you should really only need a custom tune if you have mods because different cars could potentially react differently to those mods.
2. My car feels slower after Ive been driving for a couple of minutes. I know that happens to all cars after they run for a while because they get hot but should it really be that noticeable with evos? I live in florida and its pretty damn hot right now if that matters.
3. I can always see the air bend over my hood while I drive because the engine is hot. Is that normal because of the vents?
4. My radio has no backlight. Im wondering if its burnt out or if stock usdm ix radios dont have backlights.
5. Fifth gear can sometimes be difficult to get into (I have an MR). Is this common?
6. I am kinda disappointed with the brakes. I thought they would really be powerful. The Subaru dealer I got the car from changed the pads and resurfaced the rotors. They told me they got the pads from NAPA (might have said they were NAPA brand cant remember). Could it just be crappy pads? I have a fusion I use for work and I feel that car has better brakes.
Thanks in advance for any help :^)
1. Get yourself a tune after you get mods on the car. If its 100% stock then no tune needed. Keep up on regular maintenance tuneup stuff and you will be fine if your stock.
2. If its particularly hot, the ecu may be pulling timing to keep things safe.
3. normal
4. my radio has no backlight either, as far as I know its normal.
5. I dont own an MR, sorry not familiar.
6. It could be a combination of the brake pad compounds and brake fluid condition. Also Im sure they didnt bed them in, try re bedding the pads in and see if that changes before you start replacing parts.
1/2. What he said^
3. Completely normal, the only way you won't see this heat emanating from your exhaust mani is if you get it wrapped or ceramic coated.
4. Believe that's normal for the stock radio.
5. Define difficult? Is it notchy? Does it scratch when you try to put it in 5th while at higher rpms only? Try revving to 4k and then putting it into 5th as the rpms drop; don't force it just hold it there until it lets you in, if that worked then it's most likely a synchro
6. May be the bed in, if they ARE new the dealer likely didn't bed them for you, however NAPA pads aren't that great anyhow, you can get a full front/back package of EBC Redstuff brakepads off of LancerShop.com for like 250$, will take you about an hour tops to put them on and it will most likely feel significantly better (after bed in) would also recommend doing rotors when you do pads. Most of the products that you find at NAPA/Autozone/Advanced are more or less geared towards economy styled vehicles, they aren't bad quality it's just they're usually not performance oriented, even the "sport" types, they usually consider a civic SI to be "sport".
1/2. What he said^
I would say notchy rather than anything else. Ill try out what you said on my way to work tomorrow. Glad to know that the brakes could improve from what you and tommi said. As far you guys not suggesting a tune, I know theres more to be gained from mods but plenty also from a tune on a stock car. That wasnt really my concern, it was whether a flash or custom tune would make much of a difference at that stage. Thanks for the responses guys.
I'd keep the tune stock for awhile and get used to the car as it sits. No point spending money on a tune or flash, then getting a few parts and having to get retuned. Save up, get an exhaust and a few other goodies then find a "reputable tuner" to maximize your mods. Just my opinion.
Yes. Having overly sensitive brakes is doesnt = great braking system. Go drive a brand new prius, or any commuter vehicle for that matter, they are gonna have very sensitive brakes, but that doesnt make them good performance brakes, do they? depending on how you add pressure, the evos brakes respond accordingly to give you preciseness. My mom has a bmw 335i, whiles its a very nice car, its pretty hard to modulate the brakes, they are pretty much ON-OFF, that would be pretty ****ing bad in a track situation, would it not? Get some good brake fluid, good pads, bleed properly and bed properly, your evo is a very good braking/handling vehicle. theres a reason people like to buy used evo brembos and swap them in, even STI guys who already have brembos from the factory.
But Im not talking about only when driving passively. I am aware that sensitivity does not mean the brakes perform better. I have done hard stops on both to compare them and it seemed like the fusion brakes were the same or better. Although it could be that since I didnt do them back to back, that my recollection may have not been entirely accurate. Im not complaining about the precision of the brakes but disappointed with overall stopping power but maybe thats not the cars fault due to the crappy pads they gave me and whether they did a good job installing them.
I think you'd be okay with a generic tune, since there are fewer variances than there are when dealing with a modded car, but if it's not too difficult for you to get a custom tune in terms of price and convenience (meaning the tuner isn't too far away), then you could just go for a custom tune and really maximize your gains and/or make some custom requests for the tuner to keep in mind when working on your car.
Brake fluid condition/type, tires, type of brake pads, and condition of rotors, can all play a part of your braking performance. My rotors are starting to glaze up and I can tell the braking is starting to feel really weak/mushy.
If your rotors dont show any signs of excessive glazing, then I would think it would be due to the brake pads. Some brake pad compounds have a really mushy feel to them due to the compound to make them quieter. Like I said earlier though, you may be able to at least try and re bed them in and see if that improves.
Smike
63
Apr 29, 2019 07:27 AM
D1andonlyantman
Jul 27, 2014 09:09 AM
