car not starting
Old Sep 28, 2014 | 08:23 PM
mykep83's Avatar
Lightbulb car not starting
I know I know check the battery.... but its fine.
so a little back ground
06 evolution w.w.(i know the color does not matter but hey) I am the third owner. 2nd owner had it repossessed and the bank had a new key made for it.
the car will not start occasionally.
went to breakfast a month ago drove fine there, ate and came back out and had to push start it.
two days ago wife tried to take it out and same thing.
all the interior lights come on like they are supposed to and everything acts like its supposed to act but go to turn the key over and nothing happens.
this has happened half dozen times or more.
a few times I have put cables thinking it was a dead battery and it fired up.
I HAVE CHECKED THE BATTERY, I HAVE CHECKED THE STARTER. BOTH GOOD.
possible symptoms are the key transmitter is faulting out occasionally or the clutch pedal sensor is faulting out? I am at a loss but I cannot consider it reliable right now with this issue any help on this matter is greatly appreciated
BATTERY IS GOOD
STARTER IS GOOD
CABLES ON THE BATTERY ARE GOOD
Old Sep 28, 2014 | 09:18 PM
detroit pistins's Avatar
interesting..... I had a similar issue and it ended up being the terminals on the starter getting loose from time to time.
Old Sep 28, 2014 | 09:42 PM
mykep83's Avatar
I pulled the starter to have it bench tested. he said it could use a cleaning but that it passed its inspection or test. the terminals were snug when I took it off and I checked them again when we had the problem the other day and no issues.
Old Sep 29, 2014 | 12:20 PM
EatSleepBoost's Avatar
starters can be faulty intermittently. What you need to do is if you can duplicate the issue, Use a test light or a volt meter and check the power coming down to the starter and the signal. Have somebody else try and start it while you are under the car and if you confirm you are getting proper signal and that starter will not turn its the starter.
Old Sep 29, 2014 | 08:37 PM
vanvorisdj's Avatar
Try this
https://www.evolutionm.net/forums/ev...ied-fixed.html
phyzy
20
Feb 16, 2023 06:38 PM
EvolutionTheory
10
Nov 15, 2009 07:25 AM
Kiartiger
Lancer Troubleshooting
Feb 28, 2009 01:12 AM
AznraceR
Jan 2, 2006 09:50 PM
LaNceRiTiZ
Jun 2, 2005 03:35 PM
