Car breaks up under boost even under no load (Video with DETAILED description)
#32
lets think about this practically. 2150s and a double pumper should be no where near even 80% dc let alone 130ish. either your not flowing or its going somewhere else. dc is a calculated factor and it may be a paper tiger. what are they scaled to and are you on the stock ecu?
#33
Any idea on the spec for the coils?
What could be restricting the fuel?
The tuner has em scaled pretty high, and what do you mean paper tiger?
#35
Unrelated, is it possible my wideband is reading wrong? The tuner stressed to keep the afrs near stoic, and maybe that's the issue.
The wideband bung was welded in crooked, and the tip contacts the downpipe. Would that create an issue with the wideband sensor heater circuit?
#37
And if you have driven the car (stock turbo + 2150cc inj) for a while without dialing them proper your cylinder walls and ring gaps are probably washed out. This could be easily proven/disregard with a leak-down test.
#38
Anything could happen when the sensor is heated and expanded. This installation could cause issues.
Car makes power out of boost just not in boost. (Compression is fine)
evolvedevo91
Jan 6, 2015 08:13 AM
evo9powerr
Aug 10, 2014 09:14 AM
