Evo 8 accidentally towed on dolly? Help please
#47
Don't waste your time calling a lawyer, why do you have insurance?
Do you have full coverage insurance?
just file a claim with your insurance company.
Tell them what happened and let them pay for it.
They will go after the towing company for the money lost.
GL!
GL!
#48
No, it won't.
The ONLY thing effected by the car being towed on one axle is the ACD clutch pack, that is it. The tcase "whine" comes from the ring and pinion gears which sit in an oil bath and give zero ****s as to how the car is towed. The logic you guys have saying the tcase ring and pinion are now bad would be the same logic say the rear diff is now blown up too. Its simply not.
It hurts the ACD clutch pack, and the ACD clutch pack ONLY. This is because the clutch pack is slipping the whole time its being towed, which its not design to do.
I believe the viscous coupling is going to be damaged if you don’t have acd. So, yes it probably still needs work.
#50
question: has the car been damaged by the toe truck?
question: can you therefore show or prove that it has been damaged by the toe truck?
please present the evidence to the court
going to court on a possibility that it has been damaged might not been seen as favourable to your case without the evidence
#52
no
I mean technically yes, it's no different than pushing it around, but i wouldn't go more than a few blocks and at less than 5-10 mph
there's also no safe way to tow a car with all four wheels on the ground.
#53
i thought maybe the ACD just gave up, now i think its due to towing the car,or maybe not
but i never towed the car at speeds of more than 10mph.
#54
you can flat tow a manual transmission car no problem.
That's only an issue with auto trans cars where you would have the output shaft being turned, but the pump isn't pumping fluid because the engine is off.
#55
#56
why would it be illegal? i live 9000 miles away from the united states.
sorry to hijack the other guys thread, just saw this thread and wanted to know cause i towed my car a few times.
i guess it's okay to tow if all four wheels are on the ground.
#57
Its illegal to tow a car with a rope/strap. It is legal if you use a solid "tow bar".
#58
As an attorney, and in hopes of helping out fellow EvoM members, I just want to address a common misconception that I see in a lot of these threads. Absent some agreement between the parties (e.g., a contract that allows a prevailing party to recover attorney's fees) or statutory basis, no court will award you attorney's fees for winning a case. That's how the American system is set up. Do not sue someone on the assumption you'll get fees if you win. This is only allowed in limited cases.
Also, if the claim isn't worth more than $10k, you're better of with small claims. Absent a very favorable fee agreement with a lawyer, you'll spend more for 10 hours of his work than you likely stand to recover. Suing someone is VERY expensive, emotionally exhausting, and a major time suck.
That said, best of luck to you. If you go the small claims route, I'd find a local attorney who will give you two hours of his time (obviously for a fee) to go over your documentation and legal arguments.
This is not legal advice. You're free to do what you want. Just trying to help you all out with some practical advice based on my professional experience. If you have real questions, contact a lawyer. Most give free consultations.
#59
what would you suggest to build th case up for small claims?
#60
I'm sorry but I can't give you legal advice. I'm sure there's someone in your area that does some sort of auto-mechanic negligence work on the plaintiff's side. They might be able to help you out. Sorry I can't be more helpful.
