HELP!!! No power when I turn the key to on!
Let me start from the beginning. Relocated battery to trunk. Grounded to the rear strut tower with the paint off for a good ground. After install turn the key to the first click (acc) the radio comes on then key one more click (on) everything goes dead. Then test the ground again and power is back feeding through the ground tested with test light..**then turn key back off and everything goes back to normal.
So I decided to go hook battery back up in front same result....
So now decided to unhook each wire from distribution block one buy one. found that when I disconnected the 2 white/red strip wires that run to the main fuse block (circled in red) the power goes back to the power wire and not through the ground anymore.
So I decided to check all relays all seem good 80 to 140 ohms and open and close when powered up from an external power source (an extra battery I had lying around). Now I'm out a ideas can anyone help please
evo98urv8
Feb 8, 2015 07:03 PM
SOUNDWAVE333
Evo X How Tos / Installations
Feb 7, 2014 03:57 PM
Stock-ish
Feb 9, 2011 07:30 PM
mrbkkt1
Jun 18, 2007 01:19 PM
