evo VII idle sticking
Old Feb 21, 2015 | 04:55 PM
hurdle18's Avatar
i have read about 1000 threads on this rough idle that seems to be common. the car drives fine except for the fact it will get stuck idling at 2500-3000rpm every time i come to a stop. if i bump the throttle then it will idle back down. a couple times it has even cut off at a stoplight bc it will idle down too low. my service engine light just came on and was throwing an O2 sensor code. i pulled my IAC out and turned the ignition and the IAC was functioning so now i have to clue what it could be.
Old Feb 22, 2015 | 10:34 PM
essej's Avatar
Have you tried adjusting the BISS screw? Maybe your fuel tables need to be adjusted?
Old Feb 23, 2015 | 07:15 AM
hurdle18's Avatar
i just did an EGR delete and now it won't get stuck high but it dies if i put it in neutral and come up to a stop. It tries to save it and will idle up and fall a few times b4 it cuts off.
Old Feb 23, 2015 | 08:26 AM
deza3000's Avatar
Try resetting the ecu? Disconnect the battery and leave it for half an hour, I had some rough idle, and this solved my issue.
UGTSMKD
Apr 25, 2015 10:18 PM
Toxin
15
Mar 14, 2009 01:47 PM
EVOL 8
May 3, 2005 12:54 PM
propellerhead
Jul 9, 2004 11:20 AM
BluEvo3037
11
May 24, 2004 06:13 AM
