Evo 8 Build!
Okay brotha I can tell there are some fire behind your words. This page is for the progress on my build. So how about you stop doubting, sit back and watch. Just because I dont have a million posts doesnt mean im new to all this. They dont just pick up any 20 year old to work on Lamborghini's and Ferrari's all day. Ive got it handled. Thank you.
Just noticing a distance between information given and the final concept. As a fellow technician I look at things with a similar but outside perspective. I've always liked another set of eyes when im headed into a build thread because I always miss something or concentrate on one aspect to much.
My goal was just to understand not insult.
No fire here man
My main goal is a good solid motor that will last. Jackson does all their machine work in house and they have cars with 700+awhp and 60k on the longblock never opened up. Most of these bad reviews are due to misunderstandings with the work being peformed. Not on the actual product itself. I contacted Tony with a goal of power and longevity. All of the questions I asked we answered thoroughly and made me feel very confident with my decision. Their head work from What I see is second to none. Their 20+ years of experience with the 4g63 platform also put ease on the process. I spoke to all of the engine builders listed and then some. Time is definetly not a big concern as theyve had my block for quite some time. But I believe the finished product will be more than worth the wait. Im very confindent with my decision and Tony has my trust 100%. in the end I told him my goal he set up a good estimate. Didnt over sell as I added more parts to the list and he is well aware no expense is spared with this build. A lot of the shops that are more active on the forum get a lot of shine but not every good build is on the internet. Being in the customer service/ auto repair and customisation business I can understand how customers can make a big deal out of a simple if not irrelevant problem and post all about it as ive seen a lot on this forum. I also know there are two sides to every story. All in all im rooting for the underdog on this one and I hope this build will be a stepping stone to building the rep of jackson auto machine again.
Sounds like a crazy build
Why didn't you want to build it yourself? With Lamborghini and Ferrari technician traning its a peice of cake comparatively.
Did you buy a long block there or shoot em yours?
You can save yourself a ton of money if you still have your long block.
The service manuals really detailed and lays it all out.
I was nervous when I did my 2.4 for my upcoming build I usually sent my block out(keep in mind im an ase master cert)
For some reason I always wanted to feel like it was someone else's fault haha. Call it pride before... but now it's easy man ill always build a 63/64!
Just saying if you hadn't considered....
As far as I see, it seems as a solid plan.
Just to say, (mostly to show off), the important (and the most costly thing in my opinion, eventually), is to do something without speculating any results, but to have a reason...
keep up, as you have earned my attention...
Update
The longblock is here
2.3 bottom end:
Manley Billet 100mm stroker crankshaft
Manley Turbo Tuff rods
Custom Venolia pistons +.020 10.5:1 compression
ACL race bearings
Head:
Stage 3 port and polish
Competition valve job
+1mm valves
Manley dual valve springs with titanium retainers
Manley hardend valve locks
3mm big bore lifters
Comp cams 265/265
Cometic head gasket
Accessories:
OEM gasket kit
Gates water pump
Gates kevlar timing belt
New tensioners, adjuster arm, etc.
OEM oil filter housing
AMS oil pan
ARP L19 head studs
Fluidamper
Also bought a new bike haha
2.3 bottom end:
ACL race bearings
Head:
+1mm valves
Comp cams 265/265
Cometic head gasket
Accessories:
OEM gasket kit
Gates water pump
AMS oil pan
ARP L19 head studs
Fluidamper
