I'm Back! Here is my 2004 EVO 8 Build
Were Back! Here is the latest build status with parts list:
2004 Evolution 8 GSR Black on Black
Car weighs in at 3440 lbs. with full tank of gas and Yours Truly in the seat!
Engine:
4G63 2.0L Balanced and Blueprinted
Balanced and machined stock crank
Manley 14022-4 H-Beam Rods
Manley Piston Set-Bore .20 over
ARP Main Stud Kit
ACL Race Rod Bearings
ACL Race Main Bearings
ACL 1T1219 Race Series Thrust Washer Set
GSC Race Balance Shaft Elimination Kit
ARP Head Stud Kit
Milled, Ported, and Polished Head
Supertech Racing Valve Spring Kit
Supertech Valves
Kelford 272 Exhaust/Intake Cams
Gates Timing Belts
Fluidampr Street Series Crank Pully
Torque Solutions Solid Motor and Transmission Mount Kit
Intake/Turbo/Exhaust/Cooling:
HKS Super Power Flow 200mm 4.5" MAF Adapter Filter Kit/Ceramic Coated
Stock MAF
FP Intake
FP RED JB Turbo 10.5 Ceramic Coated Housing w/18lbs wastegate
FP SS Oil Feed Line w/Filter SS Water Feed Line
GrimmSpeed 3 Port Boost Solenoid
Agency Power 2.5" Charge Pipe(LICP)/Black Ceramic Coated
ETS 24"x11.5"x3.5" Bar & Plate Core Intercooler
Stock UICP with upgraded hosing/clamps/Black Ceramic Coated
Forge BOV w/Blue Spring
Skunkworkz/Skunk2 Fully Custom Ported 68mm Throttle Body
MAP Rev 3 Modified Intake Manifold Black Ceramic Coated
FP Racing Manifold Port Matched Black Ceramic Coated
Custom Black Ceramic Coated Heat Shield
Map SS 02 Dump Housing
Megan 3" down pipe
Perrin high flow 3" cat
Custom JDM 3" Catback piping with AERO Turbine Muffler
Haste Triple Core Race Radiator
Mishimoto Slim Line Fan w/factory fan control circuit
Custom 1 off Oil Catch Can with Remote Breather
Fuel/Ignition:
Walbro 450LPH fuel pump running 12.5V, Semi Hard Wire.
Modified and Reinforced Mitsubishi Fuel Hanger w/Modified Return Y.
Russel Performance -6AN SS Feed Line w/upgraded return line
Radium Engineering Fuel Rail/Fuel Pulse Dampner
AEM Adjustable FPR
PTE 880's
Okada Direct Plasma Coils
Magnecor Spark Plug Wires
Denso IW24 Spark Plugs
160 Amp Alternator
Custom Grounding Kit
Drivetrain:
Transmission: 5 Speed GSR
Competition Clutch 5152-1620 Stage 4
Resurfaced ACT XACT Prolite Flywheel 12 lbs.
Jacks Transmission Drag Build with HKS 4.11 output gear
Agency Power 5 Speed short shifter w/stock balance weight on shaft.
Agency Power Shifter Bushings Kit
JDM Speed Shift Lever Extension/Custom Shift Knob
SS Clutch Line
Rebuilt Rear LSD with Weir Plates/Clutches
Suspension/Chassis:
BK Sport Coil Overs
Full Energy Suspension Bushing Kit
Whiteline 26mm Front Sway Bar
Whiteline Adjustable Front Sway Bar End Link Kit
AGENCY POWER 27MM REAR ADJUSTABLE SWAY BAR
Perrin Adjustable Rear Sway Bar End Link Kit
Perrin Stout Mounts
DME 3 Point Front Strut Tower Brace
DME Rear Strut Tower Brace
Ultra Racing 2 pc Side/Lower Brace Kit(Subframe Connectors)
Ultra Racing Front Lower 5 Point Brace
Brakes/Rims/Tires:
RotorPros Dimpled/Slotted Rotors
EBC Red Stuff Brake Pads
RED SS Brake Lines
StopTech STR 660 H/P Brake FLuid
Winter Rims: Motegi MR118 17" x 8" 32mm offset
Winter Tires: Cooper Weather-Master S/T 2 235/45/17
Summer Rims: Rota Grid 17" x 9" 25mm offset
Summer Tires: Cooper RS3-A 235/45/17
Aerodynamics/Body:
Custom Aluminum Aero Kit
Rexpeed Carbon Fiber Front Lip
Rexpeed Carbon Front Canards
Seibon Fiberglass Hood
Rexpeed Carbon Fiber Hood Vent
Rexpeed Carbon Fiber Vortex Generator
JDM EVO IX Rear Bumper with American crash bar
Mitsubishi OEM Window Vent Shades
SZ Rear Roof Visor
Interior:
2005 Evo MR Solid Black/Red Pinstripe Recaros, and Rear Seat
Tanaka TA-NCAM4BK Racing Harness Driver/Passenger
NRG Black 4 Point Harness Bar
Blitz Turbo Timer where clock used to be
AEM Wide Band
AEM Boost Gauge
Pioneer 4200NEX Head Unit
Pioneer Component's Door/A-Pillar/Kicker 3 way rear deck
Sundown 8" Sub/JL Audio 250x1 and 300x4.
Additional 7" x 11" Custom mounted Screen on trunk lid.
Stealth Mount Custom Overhead Console w/motorized Radar Detector
Trunk gutted and carpeted
Engine Management:
2005 EVO VIII ECU
Tephra 94170715 ROM
Full Tephra Mods w/Large Maps
MFred ECU/PSI Based Boost Control
Merlin.oz/Skunkworkz Tuned
Triple staged mapping on the fly:
25 PSI/8 Degree @ 8250 RPM/ 11.2 AFR/ 91 Pump DD Map
30 PSI/7 Degree @ 8250 RPM/ 11.2 AFR/ 91 Pump/C06 ALT/Race Map
30 PSI/7 Degree @ 8250 RPM/ 11.2 AFR/ 91 Pump LAUNCH Map
What do you all think?
Engine:
ARP Main Stud Kit
ARP Head Stud Kit
Supertech Valves
Gates Timing Belts
Stock MAF
FP Intake
Megan 3" down pipe
Fuel/Ignition:
AEM Adjustable FPR
PTE 880's
160 Amp Alternator
Drivetrain:
SS Clutch Line
Suspension/Chassis:
BK Sport Coil Overs
Perrin Stout Mounts
Brakes/Rims/Tires:
RED SS Brake Lines
Aerodynamics/Body:
SZ Rear Roof Visor
Interior:
AEM Wide Band
AEM Boost Gauge
Engine Management:
2005 EVO VIII ECU
Tephra 94170715 ROM
Currently working on some fresh pics, but if you guys go to the RADTEKSOLUTIONS link in my sig, there are pics of it at shows, prior to the motor rebuild. I had all supporting mods, except the bottom end parts already on the car at this time. My rings and clutch went out about 2.5 years ago, and my mechanic took forever to rebuild bottom end, and finish valve job on top end. Then my transmission went out after putting the HKS 4.11's in here about 2 months ago. Transmission is currently at Jacks Transmissions in Colorado getting the drag build. So as soon as it is back in the car, I will have fresh pics for you.
These pics are of the last show I did prior to rebuild. I noticed my HKS Filter and Dejon intake are not in the car yet at this show. These pics do not really do justice. But I will take a full array of pics as soon as it is out of the shop.
Remind you, this has been a 5 year project, saving, ordering, installing, waiting, etc. The last 2 years has been a pain in the ***, but the light at the end of the tunnel is drawing near. Here are some various pics taken 3-4 years ago, installing several various parts. This is myself, the grey haired mad scientist mechanic, and a couple buddies one night at the shop.
