New turbo what would go great with the new one
Ok so I have a 03 Evo 8 the mods I have now are
Walbro 255
BC 272 cams
Ams IC
Upic
Mishimoto rad
1150 FIC Injectors
I ordered the sheepeybuilt kit with the precision 6266 bb turbo will come with the mainifold downpipe 45mm turbosmart wastgate and feed lines and also a LICP
What other mods should go along with this kit to run safety its pretty much the stock engine previous owner said it has a stage 2 clutch i have no idea which clutch lol though
Walbro 255
BC 272 cams
Ams IC
Upic
Mishimoto rad
1150 FIC Injectors
So you got a $4.000 turbo kit that's capable of making 730 hp and you don't know what you need to be able to use it? Good luck. You need a ENTIRE build to get any potential out of it. The only thing you can reuse is your radiator and maybe your fmic depending on what one it is.
lol.
Clutch, intercooler, intercooler piping, boost controller, tune. You'll need bigger and injectors and fuel pump if you're going to run E85. And make sure you take it to a good tuner that is fimiliar with tuning stock block big turbo Evo's to keep the torque in check...
Craig King
10
Jun 20, 2012 04:00 PM
BEISSEN
16
Jun 26, 2011 05:36 PM
Midnighyt
Apr 1, 2010 05:12 PM
