Redline S1 Fuel injector/system cleaner
Hi guys,
Thinking about putting some fuel injector cleaner in my tank to clean injectors etc. I have decided to go with Redline S1.
I was just wondering if anyone has used this product or similar products and if there is any benefit? my car still runs fine, but I just wanted to do it as a service/maintainance.
Also I have read that you should use it towards the end of the oil cycle. I have just changed my oil about 500miles ago, should i avoid putting this in?
Any help or input on this would be much appreciated. Thanks in advance !
if youre serious about injector cleaning, you might need to go to a shop they have systems that do a rpetty good job even on car. your best bet for DIY is seafoam in your gas tank. If you put it in your vacuum line, youre going to eb cleaning the intake, and intake valves, not the injectors. Adn you'll need to change the oil ASAP at that point too as itll wash down the cylinders.
Just int he fuel tank will target your injectors.
