Can't figure out noise
Hey I have been searching different noises that people have on here and none seem to match my problem. I have a squealing noise from under hood tough part is it only happens after long drive like over 30 or 40 minutes or after driving and doing a couple pulls. I can figure out where it's coming from because the noise only happens when going over about 7 miles per hours and is consistent no matter which gear or clutch in or out or rolling in neutral always the same after 7 miles per hour. The noise goes away if I park car for extended period. Any ideas?
Thanks I can try the vid. I was think belt/pulley too but can't re create the noise when parked to isolate I was thinking of just changing all the belts and pulleys haha maybe that would fix and I have no local evo shops three hour drive is closest reputable
I would wonder if it's something in the suspension/wheel well or a drivetrain component. You mention that it's only when the car is moving faster than 7 mph right? If you have the car in neutral rolling, the engine shouldn't be under load, which means if it were a belt or something engine related it should also be manifesting at idle parked.
I would check anything rubber or silicone in your suspension, wheel well rubbing, etc...
TxFAkuma
Jul 17, 2014 06:37 PM
