Easiest way to replace rear wheel stud?
I have the rotor / caliper off. I removed the broken stud with a ball join separator and was able to shimmy it out. Now I'm trying to install the new stud, but the ebrake assembly is in the way...
Is the only way to do this to remove the hub assembly? I currently don't have an axle nut socket. Or is there some way to remove the ebrake assembly without removing the hub assembly?
In this case the e-brake assembly was removed while leaving the axle nut staked in place.
ARP Extended Rear Wheel Stud seems like a good place to start.
This video helped a lot with the e brake assembly:
I was tempted to do that, but I didn't have a slide hammer and I was really afraid of the hub being siezed to knuckle.. Next time I think I will do that.
Gtizks
Aug 20, 2016 05:29 PM
Douglas_Hammon
12
Aug 31, 2012 09:06 AM
93civEJ1
Jun 13, 2008 08:28 PM
OtownEvo
May 24, 2007 06:37 AM
Blue Evo 8
Apr 10, 2007 09:12 PM
