evo 9 bov
evo 9 bov
Decided to upgrade from my plastic stock 8 bov to a 9 bov.
Shipment just came in today, my question is, it a simple swap between the two bov? Or are there extra steps or precaution i should take before or after the initial swap.
Thanks in advance and sorry for the newbie question.
Brand new 9 bov
mounted stock location if that matters
Brand new 9 bov
yep ^^ what they said. Now is a good time to also check your rubber vacuum lines as well. Maybe use clamps or those pressure clamps you can pick up easily at hardware/pepboys. I have used zipties for some time and a few did give out perhaps due to the heat cycle...then again i've had those zipties for 2+ years.
Just make sure you install it in the correct direction. It goes the same way as the 8 bov..
dan08
Sep 25, 2013 08:43 PM
dvd_mi
16
Nov 19, 2009 05:27 PM
evo150
Mar 13, 2006 06:31 PM
Sol-leks
Oct 21, 2004 01:02 PM
