DIY HVAC vacuum pump rental,refrigerant+oil volumes
Has anyone Rented a vacuum pump and successfully re-filled their own system?
I'm looking for the following information.
Where, (ie. Autozone)?
How much $ to rent?
Basic procedure?
How much oil/ refrigerant balance?
Thanks!
How much $ to rent?
Basic procedure?
Thanks!
Never heard of renting this equipment, if you were local to me I'd help you out. You'll need gauges with r134 hoses or adapters and a Vacuum gauge as well. What type of repair are you doing?
I pulled out the condenser core while preforming the dreaded early evo blender box door TSB. below. Now I need to vac the system, calculate oil/refrigerant volume, recharge and check the air gap on the compressor clutch. I found the basic info I need, now just looking for any tips or wisdom from anyone who has done this before.
https://www.evolutionm.net/forums/ev...ega-guide.html
Autozone allegedly rents the equipment.
http://www.autozone.com/landing/page...omplete-repair
From the FSM:
"55-72"
"HEATER, AIR CONDITIONING AND VENTILATION"
" ON-VEHICLE SERVICE "
"REFILLING OF OIL IN THE A/C SYSTEM"
"Too little oil will provide inadequate compressor lubrication and cause a compressor failure. Too much oil will increase dis- charge air temperature."
"When a compressor is installed at the factory, it contains 140"
"cm3 (4.7 floz) of refrigerant oil. While the A/C system is in oper- ation, the oil is carried through the entire system by the refriger- ant. Some of this oil will be trapped and retained in various parts of the system."
"When the following system components are changed, it is nec- essary to add oil to the system to replace the oil being removed with the component."
"Compressor oil: SUN PAG 56 Quantity:"
"• Evaporator: 60 cm3 (2.0 floz)"
"• Condenser: 15 cm3 (0.5 floz)"
"• Suction hose: 10 cm3 (0.3 floz)"
"PERFORMANCE TEST"
"M1552001400300"
"LOW-PRESSURE"
"VALVE"
"CHARGING HOSE (BLUE)"
"ADAPTOR VALVE (FOR"
"LOW-PRES- SURE)"
"HIGH-PRESSURE"
"VALVE"
"GAUGE MANIFOLD CHARGING"
"HOSE (RED)"
"A SLEEVE"
"ADAPTOR VALVE"
"1. The vehicles to be tested should be in a place that is not in"
"direct sunlight."
"2. Close the high and low-pressure valve of the gauge manifold."
"3. Connect the charging hose (blue) to the low-pressure valve and connect the charging hose (red) to the high-pressure valve of the gauge manifold."
"4. Install the quick joint (for low-pressure) to the charging hose (blue), and connect the quick joint (for high-pressure) to the charging hose (red)."
"CAUTION"
"• To connect the quick joint, press section A firmly against the service valve until a click is heard."
"• When connecting, run your hand along the hose while pressing to ensure that there are no bends in the hose."
"NOTE: The high-pressure service valve is on the liquid pipe A and the low-pressure service valve is on the suction hose."
"5. Connect the quick joint (for low-pressure) to the low- pressure service valve and connect the quick joint (for high-"
"LOW-"
"HIGH-"
"(FOR HIGH-"
"PRESSURE PRESSURE"
"PRESSURE)"
"pressure) to the high-pressure service valve."
"SERVICE"
"VALVE"
"SERVICE"
"VALVE"
"AC001388AB"
"6. Start the engine."
"7. Set the A/C controls as follows:"
"• A/C switch: A/C − ON position"
"• Mode selection: FACE position"
"• Temperature control: MAXIMUM COOLING position"
"• Air selection: RECIRCULATION position"
"• Blower switch: ""4"" (HI) position"
"8. Adjust engine speed to idle speed with A/C clutch engaged."
"9. Engine should be warmed up with doors and windows open."
From the FSM:
"55-72"
"PERFORMANCE TEST"
"M1552001400300"
"LOW-PRESSURE"
"VALVE"
"LOW-PRES- SURE)"
"HIGH-PRESSURE"
"VALVE"
"HOSE (RED)"
"A SLEEVE"
"ADAPTOR VALVE"
"direct sunlight."
"CAUTION"
"LOW-"
"HIGH-"
"(FOR HIGH-"
"PRESSURE PRESSURE"
"PRESSURE)"
"SERVICE"
"VALVE"
"SERVICE"
"VALVE"
"AC001388AB"
From the FSM:
"55-72"
"PERFORMANCE TEST"
"M1552001400300"
"LOW-PRESSURE"
"VALVE"
"LOW-PRES- SURE)"
"HIGH-PRESSURE"
"VALVE"
"HOSE (RED)"
"A SLEEVE"
"ADAPTOR VALVE"
"direct sunlight."
"CAUTION"
"LOW-"
"HIGH-"
"(FOR HIGH-"
"PRESSURE PRESSURE"
"PRESSURE)"
"SERVICE"
"VALVE"
"SERVICE"
"VALVE"
"AC001388AB"
From the FSM:
"55-72"
"PERFORMANCE TEST"
"M1552001400300"
"LOW-PRESSURE"
"VALVE"
"LOW-PRES- SURE)"
"HIGH-PRESSURE"
"VALVE"
"HOSE (RED)"
"A SLEEVE"
"ADAPTOR VALVE"
"direct sunlight."
"CAUTION"
"LOW-"
"HIGH-"
"(FOR HIGH-"
"PRESSURE PRESSURE"
"PRESSURE)"
"SERVICE"
"VALVE"
"SERVICE"
"VALVE"
"AC001388AB"
Are you sure you didn't remove the evaporator ? That's the coil inside the cabin. Condensor is against your radiator. Basically you add the oil specified, best place would be the compressor, but you could hand pump into the suction line if you had to. Then pull a Vacuum below 500 micron, break the vacuum with r134a up to 0PSIG, pull another vacuum below 500 micron, then charge with r134a, you can weigh the charge in, or charge low and bump it up based on superheated / suction pressure while it's running.
EvoXColetta
Jan 27, 2010 11:19 PM
EvoIXMR
Jun 12, 2008 08:16 PM
xman23
24
Sep 4, 2007 08:08 AM
