Who runs a catch can?
Personally, I wouldn't if you're on stock block. The only reason I'd see to run a catch can would be because of crankcase pressure or maybe e85 gunk. Other than those two reasons, I can't see why anyone would run it. I myself am looking to get one because fp's ballbearing turbos have their infamous oil leakages because it's sensitive to the crankcase pressure.
Maybe I'm missing something? I dont know, if you're system is working fine I suggest you not to mess with it
Just my $.02
Just my $.02
Just my $.02
Just my $.02
Using a catch can cleans what your motor is breathing in.
I'm on stock block, I use a catchcan
I'm not stock but not highly modded (basic bolt on really) and i use a catch can. I use a clear hose to connect everything and you can actually see all the oil that would have ended up in the intake pipe. My intake pipe has been clean of oil ever since i've installed it. To be honest, i don't remember why i bought one to begin with (this was back in 2005 i think), but i have it, and i use it.
I'm actually running two catch cans, cuz I modified cheap ones off ebay. One between the plenum and where the PCV valve used to be, and one between the side valve cover vent and the intake pipe right before the turbo intake. (SD, no MAF). I'm also using a Krank Vent check valve coming right off the plenum to keep from putting boost pressure into the catch can.
What kind of tubing are ppl using to their catch cans? Don't want to use silicon hose, as engine oil degrades it, but the clear poly type of hose I was using collapsed from the engine bay heat.
BaumBizzle
17
Sep 24, 2012 11:59 AM
anthonyrb98
50
Sep 11, 2011 07:49 AM
anthonyrb98
Northwest Region
Aug 25, 2011 06:13 AM
riceball777
14
Dec 23, 2006 09:39 PM
