crazy high fuel consumption
what would cause some ridiculous fuel consumption?
I have noticed I fill up a lot so did some tests.
I only managed to drive 165KM on 23.36L which is a fuel consumption of around 14L/100KM or 7.06KM/L
Surely that is a bit high for an Evo.
How do I bring this down? Its my daily and its costing me a fortune in petrol.
I have no CEL on but car has done 200,000Ks+ so I might replace the O2 sensor for maintenance anyway.
Will check the MAF this weekend, grab myself some MAF cleaner and get it a good going over. Im sure it isn't leaking any fuel around the injectors but I don't know if they are leaking internally.
I sometimes get pops or a mild bang between slow shifts if im granny driving. Don't know if that has anything to do with it.
I would be very happy with 400ks. Is this for an Evo 5 too? At the moment I would be lucky to get 300 and that is with driving sensibly.
Kaj, No wideband on it but I should be able to borrow one.
FossilAus, Yep get a pop on a slow gear change, no pops if I smash through the gears. Will change plugs for good measure, didn't change them last service as they "appeared" to be fine.
So far ill start with the easy options. I have Friday off work so will get investigating. MAF, plugs and visable fuel leaks first then ill track down a wideband if none of those appear to be not up to spec.
Car is reasonably stock, stock tune, TD05 20g turbo, 1 bar boost, front mount and a pod filter so I don't see one of those mods effecting fuel econ especially if I am trying to drive to save fuel on my commutes.
