Old / Current GSX owners get in here, questions...
Specs provided by OEM workshop manuals in both cases :
Power transfer on both cars is 50/50
2G weighs 3145-3223, EVO 3263-3298
Weight distribution on both cars is 60/40
EVO has much quicker steering ratio
2Gs have potentially better front suspension - better roll centre and camber control
EVO has a better rear LSD
EVO brakes are an order of magnitude better than DSMs.
Track's the same
2G DSM is several inches lower, which suggests (but does not prove) a lower CG
Despite the same track, the EVO is an inch wider.
2G is shorter overall
2G has shorter wheelbase than Evo - depends on use as to + or -
Evo has _lots_ more power !!
Stock for stock, a 2g pales in comparison.
Modified it simply becomes an arms race, the most money invariably wins.
Right now, Quaife, Kaaz, and Cusco front/centre/rear LSDs are available for DSMs - advantage DSM; Ohlins, Penske, Moton, etc etc are available for the EVO - Penskes are the only high-end suspension available for the DSM - advantage EVO. In the USA, the depth of engine tuning expertise for the DSMs is huge, the EVOs appear to be only scratching the surface compared to Europe - advantage DSM.
The reality is that 2G development is pretty much dead, whereas Evo development is stumbling ahead with enthusiasm.
Charles
Track's the same
Charles
4g63girl
11
Mar 19, 2012 09:38 PM
