Need advice. My HVAC lights don't work after airbag recall.
I have been out of town for 2 weeks, so last night was the first time that I drove my car at night since getting the airbag replaced 3 weeks ago. When I turned my lights on the HVAC panel was all dark. I would like to avoid going back to the dealer, because it is 45 minutes away, and I hate sitting in a dealer waiting for my car. I am hoping it is something simple like a fuse, or plug. I doubt it is the bulbs, because all 3 would have to have coincidentally burned out at the same time the some time between the morning I took the car in and last night. I also would be surprised to find it is a fuse for just that panel. Is there a plug that could be undone? how hard is it to access?
I'd check the connector to make sure it is tight... if those are the -only- bulbs that are not working (dash lighting works etc) then it is only expected to be the connector or the bulbs really. These bulbs DO fail a lot during these jobs simply due to the age and not liking being jostled around. I have to replace either a meter back light bulb or a check engine light bulb on every second or third one I do. Sucks. Check the connector first though; either pull the radio out and reach behind the AC (The black connector on bottom is the one you are concerned with, not the white one on top), or you may be able to take the storage bin under the AC controls out and reach from below.
to answer your question about access, its very simple. You just remove the HVAC knobs and then there are 2 screws that need to be removed. After that you simply pry off the bezel around the radio and the hvac controls. Be gentle but firm when removing it and if it feel like its binding up try pulling from a different position.
lancer0220
Jan 6, 2012 10:15 PM
