Buschur 3" Catback Exhaust Question
So, got lucky and found a low priced 2nd hand Buschur exhaust, but have a few questions. I'm removing my eBay 3" exhaust, which mounted on the factory exhaust hangars like the stock exhaust. Apparently the Buschur exhaust uses bolts through the rubber mounts, or maybe more? Can anyone chime in and let me know what hardware I'll need to install. I also noticed that I was getting a little blow by through the slip on clamp, figure I would use some high temp exhaust RTV to resolve this, has this worked for others? Figure I would try that before getting a new clamp.
Mounts with a bolt above the muffler and a bolt under the rear diff. Try using a high torque air gun to tighten the clamp. Bolts need to have giant washers on both sides of the rubber hangers to tighten nuts down, and bolt length needs to be about and inch longer than the thickness off the rubber hangers.
Thanks for the reply, I've got a good idea for the bolt size now. However, looking at the mount near the exhaust tip, with the tip angled correctly, the mount doesn't align with the exhaust hanger to put a bolt through. Did the exhaust come with a bracket and two bolts to line up correctly? See the pic below, that's my alignment with the tip angled correctly.
I bought the kit used, trust me, I'd love to have all the hardware come with it, and the gaskets. I don't want to bother buschur, seems rude to me to ask to buy hardware but not buy the kit, that's just my thoughts. I'll just be looking for a bracket or piece of metal I can use I suppose, be nice if someone had a pic of it.
johnson81420
14
May 5, 2019 06:12 PM
ESP3_925
Apr 8, 2015 02:20 AM
johnson81420
Apr 21, 2012 09:37 AM
yoyoyoyoming
Aug 1, 2004 06:59 PM
