no AYC, ACD?
Old Aug 22, 2002, 02:42 AM
  #61
MrAWD's Avatar
Originally posted by Guack007
I have a ? MrAWD
Does the ACD vary the percentage of front to rear power beyond the setting it is programed for (ie. even though TARMAC mode is 60/40 rear to front it will vary the percentage based on inputs)?
The difference between the mods (T, G, S) is basically how fast the ACD is going to react. For the "S" mode it has the fastest response which gives us the quickest locking of the center diff. Moving more toward the "T" mode, you get center diff opened longer.
In any mode, ECU will correct how much you are going to get on each side of the car or each of the rear wheels according the input from the sensors. Let say that you are in the middle of the turn and accelerating, if you increase the steering angle, more of the power will move to the outside rear wheel which will rotate the car even more.
One the other end if you decrease the steering input, than more power will more to the inside rear wheel and with a more corrections front wheels will get more grip too.
So, to answer your question, it will modulate the ratio as much as it sees fit. I don't really believe that there is such a thing as the 60:40 or so. The thing is that regardless of the mode, ones you lock the steering wheel, your car will be doing donuts (which will have completely opened center diff and most of the power on the outside rear, which passes 60:40 or anything else)!
Of course, this is all IMHO
Mr AWD
Old Aug 22, 2002, 05:45 AM
  #62
Guack007's Avatar
Thnx for the input. I just hope that when I get an Evolution 8 my driving skill will be able to stay in sync with the cars potential.
picco97
19
May 24, 2012 01:54 AM
Lancer sPie
Canadian Forum
14
Feb 24, 2011 01:59 PM
Evilution
Feb 11, 2003 02:16 PM
Infinity
Dec 17, 2002 05:50 PM
AznRidah
Mar 4, 2002 02:01 AM
Quick Reply: no AYC, ACD?
