Clutch switch and interlock switch
Old Nov 18, 2015 | 05:55 PM
Teufel's Avatar
What is the differance between the 2???
Old Nov 28, 2015 | 12:42 AM
qsiguy's Avatar
Interlock switch gets pressed when the clutch is fully depressed and is interlocked with the starter motor. Clutch pedal position switch gets pressed when you release the clutch. One thing I believe this switch controls is the "vehicle not moving/clutch depressed rev limiter" for launch control. With the clutch out the rev limiter is higher, with it pressed in and vehicle not moving, the limiter is lowered to 5k I believe. Unless, of course, you have a custom tune and they changed the rev limiters.
These switches are most likely tied to some other controls but I believe these are the two main things.
Old Nov 28, 2015 | 05:05 PM
Teufel's Avatar
Thank you very much
D2003
Jun 25, 2018 02:08 PM
Johnboy1065
Jul 14, 2008 11:26 AM
mitsuatb
Sep 2, 2007 04:04 PM
