Bought a wrecked evo. help identify previous owner/give me advice
Hey guys brand new noob here so bare with me but Like the tittle states I bought a 2004 evo with 118,xxx miles from SEATTLE WA. If anyone knows who the
previous owner may be please pm me.
Starts right up and looks to have been slightly modified. I called english racing and tried to get them to identify it by vin but unfortunately they said I need the persons name so i can get any record of work that been done. I would love to know whats been done mod wise and maintenance etc. They have relocated some stuff (batteries in the trunk, fuse box down behind bumper, ac gone)
Im also an evo noob and don’t really know whats stock on here and whats not, so if any of you can tell me from the pictures i attached whats oem and whats not that would be great too! Im deciding if its worth the rebuild or if i should send it back to auction or part it.
Things i know.
ETS (i belive) headers
Stock(?) turbo, no shaft play
fuel lab management
block looks really fresh (coated black, is that how it comes stock?)
stock upper intercooler piping aftermarket lower (not pictured)
fatty radiator and front mount (some damaged bristles but holds psi)
no exhuast
no wastegate ?
anyways let me know what you guys think from the pictures I posted and keep tuned for updates
thanks
Things i know.
fuel lab management
no exhuast
no wastegate ?
thanks
ets i belive
no ac
i hope the numbers are legible, is this thing stock?
wtf goes in this hole ;O
are these gears stock? I also got a date thats scribbled right behind them thats from late 2013
fuse box relocate.
Should i try and get to the ecu maybe and what other things should i dig around in / take pix of so you guys can help me figure out wtf this thing has been through? i can use all the help I need!
so the breather hole just gets a rubber plug, gotcha thanks.
just ordered a core support assembly for $150 that gonna be here tues.
I don't think that's an ETS manifold unless its an old one. It looks nothing like the pictures on their site.
The "hole" in the top of the trans just needs the plug put in it. That is there so the shaft for the clutch fork can be removed. It's supposed to be there, Mitsubishi puts a freeze plug in it to prevent debris getting into the bell housing.
Originally Posted by STLEV[INDENT
[/INDENT]OIX;11541524]Power steering has been relocated as well. does the vehicle crank/run?
now I just gotta pick through the car and see what's still left of the mods also try and contact previous owner for any receipts as I plan to sell after winter!
Here's the mid list for those interested:
Conservative Speed Density tune for daily driving.
Engine was completely pulled and gone throu
Wire tuck and freshly painted engine bay.
Cleaned up and relocated ps reservoir and much more
ENGINE/DRIVETAIN
New timing belt kit
New Oem water pump
Oem seals and gaskets
Oem tensioners
All new fluids Amsoil synthetic
Amsoil synchromesh
Daiqueen T-case fluid
Brand new Full size aluminum radiator
Brian Crower valve springs and retainers
New valve stem seals
Kelford 272 cams
Arp headstuds
Gsc No tick lifters
Walbro 450 to -8an feed with inline filter
3" alumimun charge piping
Tial q 50mm bov
Ported intake manifold
Thermal gasket
Allen dress up bolts
Ets slim battery kit
Ngk 7 series plugs
Stm stainless clutch line
Stm stainless valve cover bolts
Stm egr delete
Torque solution shifter bushings
Fuel lab regulator
Stm -8 an fuel rail fittings
-8an fuel lines
Aem Electronic boost solenoid
12" slim fan
Brand new full size radiator
New oem radiator hoses with t-bolt clamps
Stm radiator brackets
Cf carbing craft
Brand new 3.5" intercooler
New intake
69K mi evo 9 turbo kit swap
New Megan Tubular manifold
New 3" megan downpipe
Torque solution roller stop mount
Torque Solution rear diff mount
Act street clutch
New oem rear lower lca bushings
Perrin psrs zero bushings
Brand new starter
Buschur sd exhaust
All new bulbs all around
New hid 5k bulbs
New 3k yellow hid fogs
Led license plate lights
WHEELS/SUSPENSION
Tenabe gf210 springs.
Evo 9 bbs mr wheels
235/45/17 Yokahoma Advans
20MM spacers in front
12mm spacers rear
Goodridge stainless brake lines
Whiteline steering rack bushings
Arp extended studs
Black calipers REDONE in black
Powerslot rotors
Hawk pads
New hubs/wheel bearings
Brand new tie rods
EXTERIOR
rs trunk wingless
nose chop
New wiper blades
Do luck lip
New oem jdm rear bumper
New oem window visors
oem vortex generator
Evo 7 tailights
Cf bumper ducts
Rexspeed Carbon exhaust shield
INTERIOR
Pioneer bluetooth deck
New Oem mitsubishi floor mats
Autometer 60 psi boost gauge
Stm fuel pump wire kit
Skunk2 shift knob
Black Leather interior
10% tint
Unuselectus
Jan 18, 2018 07:56 AM
JReid
Southeast Region
Apr 25, 2013 06:56 PM
superfast
22
Feb 21, 2013 10:46 AM
