Can someone tell me what this line goes to?
As the title states, can someone please tell me where the line, in the picture below, goes to? The line starts off as a hard line and goes somewhere underneath the car somewhere below the brake booster and clutch master cylinder. I know someone here on EvoM will know where this goes!
Thanks in advance!
Thanks in advance!
It's from EGR setup. the line that runs to the charcoal canister in the back bumper. you can either put the check valve in, or just leave it, or pull it out.somebody removed/ blocked EGR system on your car.which is a good thing.
It's not the EGR, it's EVAP. And it's not a big deal. The codes for it are likely eliminated in the tune.
Thank you to both of the above posters!! I was worried it had something to do with the ACD pump. Would it be reasonable to assume that the section of missing hose, underneath the car, on the driver's side rear, by the fuel tank, is a part of the above-referenced EGR system? Possibly part of the plumbing to the charcoal canister that's mentioned above?
It is reasonable to assume it is part of the EVAP system which is usually eliminated along with the EGR system. You might try reading through this thread to confirm.
https://www.evolutionm.net/forums/ev...-canister.html
Last edited by Terror Rising; Dec 8, 2015 at 04:40 PM. Reason: Corrected EGR vs EVAP (sorry letsgetthisdone)
It is NOT anything to do with EGR. It is ONLY an EVAP line to the charcoal canister.
EGR = Exhasut Gas Recirculation. It recirculates exhaust gas to the intake manifold. The EGR valve on these cars is mounted on the #4 runner of the intake manifold.
EVAP = is a sealed ventilation system for the fuel tank. It takes fuel vaper, puts it into the charcoal canister, then sends it up into the intake manifold, or vents it to the atmosphere.
They are two distinct and separate systems, that are not related in any way. Please get that in your head and forget the bad info that was posted before me.
anjapower
Dec 21, 2006 06:53 PM
Tofurky
May 12, 2004 02:12 PM
redbeard
19
Nov 12, 2002 03:59 PM
