Road race reliability
#31
check out the racefab wet sump pan, theres a thread around here somewhere about it.
i dont like the decision to go 2.3L personally. it looks like your willing to spend the money to use good parts...i still think a 2.1 LR and EFR8374 would be an amazing and reliable setup, although it cost a little more due to the few extra bits needed to run the 4g64 block. hell, with an efr even a 2.0 LR would probably be fine. side loading and rod/stroke ratio are something worth thinking about if you really have reliability in mind imho.
I'll take a look at the race fab - looks interesting!
Thanks!
S.
#32
the problem with the fp green is that now that it comes with the stainless housing its awesome fast spool has been changed. i believe even in ball bearing its spooling no earlier than 4000rpm.
honestly if you have the money, something like an EFR 7163 sounds like exactly what your after or maybe even an 8374. i believe the 7163 has no issue doing 450-500whp with damn near stock like spool. both full race and cbrd offer kits
#33
#34
I went through the discussions with Tom, and ended up at the 2.3 because of my intended use. The extra low down torque will be really useful after hard braking in to a low speed corner (like turn 11 at Laguna!), and I don't need super high RPMs so the stroke limiting the rpm is not a big deal for me (limiting myself to about 7500-7800). Also, the extra displacement should allow me to build exhaust flow quicker, improving turbo spool. Also, the car will be daily driven, and the 2.3 will generally feel better on the street (because of the extra low torque).
Thanks!
S.
Thanks!
S.
just want you to be fully informed. i think there are a large group of us track guys that would vote against a 2.3 even though we would all probably enjoy the higher torque and faster spool. i think i said it before, but i personally saw 2 high end shop built 2.3's last 2 events or less in a time attack format, not HPDE long sessions.
#35
I dont like the decision to go 2.3L personally. it looks like your willing to spend the money to use good parts...i still think a 2.1 LR and EFR8374 would be an amazing and reliable setup, although it cost a little more due to the few extra bits needed to run the 4g64 block. hell, with an efr even a 2.0 LR would probably be fine. side loading and rod/stroke ratio are something worth thinking about if you really have reliability in mind imho.
#36
yeah theres multiple factors, and considering you spend the majority of a track sesion at almost 5k or higher you just cant expect a reasonable lifespan out of a 2.3 imho.
i can tell you on my setup im often looking for MORE rpm to extend gears out, if i had to drop the rev limit 1000rpm, i would not be happy.
#38
For anyone interested:
I found a California supplier for oil pans. The closest comparison would be the RaceFab pans. They will have the same features with exception of moving the oil pick up, the international shipping, wait, and cost LOL. They are not vendors, so i won't post pricing, options, etc. Just letting everyone know. PM me if you are interested.
#39
I'm so glad you bumped this thread. I've been looking for a do it all build that can reliably be beaten on for extended periods of time and was looking at a 2.4.
A 2.4 LR hasn't been mentioned here. Would it be worth it to sacrifice spool and go 2.1 to have the most reliable setup? I do not have a block for a core but my stock crank might actually be fine because I just broke a rod.
#40
Put a 94mm crank with 159mm rods in the 2.4 block. You'll get a 2.235L motor that will be plenty reliable.
#41
Originally Posted by ridenrunwv
Think it would be worth the added cost if my stock crank is good?
Brian@RRM
09+ Ralliart Show and Shine
34
Dec 31, 2009 09:09 AM
