Weird acceleration on Evo 9
I noticed a problem when driving the car for long periods of time. The problem that I have is after driving for more than 20 miles consistently on the highway, the car starts to accelerate sluggish. I also noticed that if Im cruising at 40 and go wot and just back off throttle to 85-90%, the car accelerates faster. I've been dealing with this issue for about a year now. I've change wires, coils, injectors, spark plugs, did boost leak tests, changed o2 sensor, pvc valve, and egr ( need to just take that off eventually) compression test 165 across the board. My mpg varies 190 to 250 with regular driving. I'm lost. No check engine lights. It does idle lumpy at times. Acceleration over 100mph takes forever.
This Evo is stock. Cat was dug out recently thinking it was that cat and was going full exuast at some point. The problem was happening before that. And it's still happening. Before I tune I want it to run good stock. This car has 128k miles.
I'm not the original owner, I wish I didn't sell my evo back in 2008. But I know its stock. I changed the valve cover seal about a year ago and after 128k miles, it still looks brand new. I have a tactrix cable from my previous car and did look into the tune and it looked stock. But the car was fine at one point of me purchasing it. Is it possible to have the spring on the throttle body to not wound tight enough after the shaft seal install? In evo's scan it reads 100% at wot.
I hit 320 a handful of times many years ago while on stock turbo between 2006-2010, been running e85 after that and now a larger turbo.
The oink rich you speak of is only during full throttle, not when cruising around out of boost.
