Help with Evo intake sound different like a loose clamp maybe?
2 days ago my Evo started making a new sound. I first noticed sound at 3000 RPM. The performance of the car still feels the same.
It sounded intake related as it would only make the sound when the turbo was spooling up. I sound say it sounds like a aftermarket intake, but i don't know what most sound like.
I have K&N Drop in filter its almost 2 years old, I washed the filter even though I was not that dirty and its still making the same sound.
I took it to the dealership to get the oil changed they looked at it and said everything looked fine, said that it might be a loose clamp but to do a more detailed look it was going to cost $120, and I don't have any money to spend.
Tomorrow I am going to check every clamp I can check around the intake since then the car will be cold. Anyone know what else this could be?
Not sure what either of those are, my car is 100% stock expect the K&N Drop in filter. Have Greddy turbo timer + greddy profec b (no providing any boost its just for digital PSI)
It does maybe sound like a boost leak because it does get little louder as you go up in RPM go up and I am building more boost.
I am looking at this https://www.evolutionm.net/forums/ev...er-5-02-a.html look like a really cheap tester to make myself, the dude says " And get some air in there, using an air compressor or a compressed air can" I don't have any of those expect the air can for cleaning computer parts.
You're in SOCAL? There are like 10 shops you can take it too, haha. MAF = Mass Air Flow sensor and usually a boost leak on this the car will run like crap. A evo tuned on speed density removes the MAF and a small leak won't seem to affect it, even though you'd probably not be hitting the proper boost when going WOT. But I would take it to a shop, I think even FireStone has a smoke tester
Thanks guys for the reply, but I am looking for the lowest cost options here, I am willing to take it to a local tuner shop but that doesn't sound free.
Been watching videos on the net on how to test it, I can do a soap spray test while the car is running on possible places were leaks are, or I can hook up an air compressor, I don't have one, or know anyone with one.
I think this is a boost leak, but I am looking at my boost gauges, the built in ones and the greddy ones and they are saying I am boosting the normal amount or close to it, not going to lie I do feel slower or laggyer throttle response when boosting though.
I live in Fullerton now BTW, I am just trying to address the urgency of this issue? Should I avoid using my car?
Thats cool man appreciate it, but I really want to fix this myself, I am a big DIYer.
I saw at Walmart a compressor for $55 not bad, i might need to compressor just to have other then using it to fix my car. Going to see if there are better deal out there.
I been really avoid using my car now and when I do I don't go on boost, I am not sure how safe for the engine to drive when the air fuel mixture is going to be off.
I respect that, but firstly, a cheap/small compressor like that is unlikely to be able to provide constant pressure for the test (i had this problem with a home depot compressor)
secondly, a drop in filter would not throw your AFR's off, not greatly atleast, the evo fuel maps are pig rich from the factory, so that half an afr drop in fuel mixture will actually help you not hurt you, and if your intake was super loose like you are claiming it to be, your mass airflow would get incorrect readings, therefore the car would run lean and studded and stall, what you are describing does not seem that drastic and crazy. post a video please.
Here is what it sounds like, its hard to pick out but its sounds like a train intake or something. http://sendvid.com/gs8yw89k
I mostly drive at nights and its not as loud as its during the day.
04Evo851374
Apr 14, 2012 01:43 AM
LIL EVOL
May 17, 2007 09:39 PM
adotwhite
Apr 7, 2005 10:54 PM
vegasboy301
Aug 31, 2004 04:16 PM
