Tial q BOV right spring??
I put a Tial q bov vta on my evo 9 running speed density. At idel the bov opens a little and let's air out with a small hissing noise... And sometimes when I don't hit full boost it reacts weird. I have a 10psi spring in it and didn't know what spring to get because the car didn't come with a gauge. Do I have the wrong spring? If so what spring should I get? I know I need to know the vacuum to find out the correct spring but I don't have a boost gauge yet to know that. Thanks in advance!
You have already resolved your own problem in your post.... You need a gauge.
Then you will know what spring to purchase...
http://www.tialsport.com/documents/w3_tial_qqr_sp.pdf
I'm not sure if it's normal or not but I didn't like it. Since you are on SD it's not effecting anything. Try to shim it with washers before you go with different spring or if you can live with that just leave it. I know on tial QR is normal because it's recirculating valve.
itsmrrizz2you
Oct 3, 2012 08:51 AM
turboDan
Mar 21, 2006 07:26 AM
