Resonated test pipe
Resonated test pipe
Hello,
I know I should search the forum first before posting but I want to know more experiences about people having resonated test pipes in california, more specific norcal. The city i live in is quite small and it's mainly for college. Is it worth it to get the test pipe and has anyone actually got caught by a cop for it? I was against it until i saw the hp difference on my friends with the test pipe. So far, i only have basic bolt ons. How often will it backfire like situation wise. My friend drives an STI and his does it when he redline it. Is that the only time it would backfire? Would it backfire if i drive normally? i usually shift at 4k rpm. I just don't want to risk it if it's random even at low speeds. Please share experience! Thank you.
For sure, pull that cat off & install the test pipe. I run a non resonated test pipe but my mid-pipe is resonated as well as the rear muffler (full 3" Invidia DP & exhaust). You will be needing a tune!
I live in the South (So.Cal). Turbo cars have a natural muffler & are relatively quiet
No backfires to worry about if youre just referring to the test pipe. Backfiring may either be purposely involved in the tune or some type of engine issue. You shouldnt be backfiring
weeeeeeeeee (Mar 17, 2016)
e-85 smells a whole lot better without a cat then gasoline. To answer your question though, yah it gonna smell. How bad it smells will be determined by how fast you are moving.
Hmm, I think i will just go on E85 then with the straight pipe. I can pretty easily get E85 here but the problem is my tuner told me my stock clutch might not hold. I'm currently at 262 awhp (viii) on a mustang dyno. I told them and they said clutch might slip because of too much power/torque. I was originally planned to do E85, straight pipe and the whole intercooler but my tuner said the E85 might increase it pass the clutch's limit so i decided to not go on E85 yet till later when i save enough for a new clutch.
evoluXrichie
Mar 14, 2009 03:30 AM
BallinAssRSvIII
Midwest Region
Jun 27, 2008 10:34 AM
5k6
11
Jun 6, 2006 07:20 AM
