Starter wire blows fuse??????
I just replaced my MAP sensor in my 05 Evo 8 with an Omni 4 bar. I recently had the code pop up that my sensor was bad. I contacted Bob at Omni and let him know. They replaced it for free. Awesome customer service!!! So I got the new one and put it in and it idled better. I took it out to drive and it stalls out again. CEL comes on. I am on my way to take it to get the code checked into town and every time I go into neutral the car stalls. Probably stalled 5-6 times. When I pull into advanced auto my car will not even start anymore. I turn the key and all the lights come and nothing is dim. However I hear something click up front every time I try. It just won't crank. I check a couple fuses and they where all good. I recently did a battery relocate to the back and the distribution block has two 30 amp fuses. The fuse with the starter wire going to it was blown. It was a 30amp. I replaced it with a 30 and it blew again, I replaced it with a 50 and then an 80 and then a 100. All of them blew. I ran a direct line from the starter to the battery in the back and it blew 100 amp fuse. I ran a new wire from the starter to the distribution block and blew the 50 amp. I do not know what else to do. I am pretty much stumped as I ran a new wire from it and the car ran prior in the day. At advanced the only code they read was the MAP sensor again so I'm thinking that problem will be in the wiring for it. I've never heard of this happening before and searched for it with no results. The battery terminals are brand new and I had the battery tested while at advanced so I know it is good. Any help is appreciated.
SteveR22 (Nov 23, 2021)
For some reason the engine is now hard to crank. The starter will pull as much amperage as necessary. I saw a starter on a Mini Cooper pull 400 amps in a youtube video where the alternator was seized.
I'd suggest pulling the accessory belt and spinning all of the accessories and idler pulleys. Then turn the engine over by hand to see how hard it cranks. If all is okay there then probably the starter.
What gauge wire did you use? If it's too small you will have too much of a draw causing it to pop a fuse. Did this work before you moved it to the back? If so you know your problem is somewhere with the install. Check your ground and make sure it is good also. Bare steel on that is the best. Good luck.
Engine does not crank (seized alternator) - Mini Cooper - YouTube
As of now to finish this thread off the car starts. Without a fuse between the starter and the battery. I ran a separate wire to the alternator to the battery with a fuse and it didn't blow. I order another distro block that I think is better but it will have a fuse in it. If it comes down to it I'll just run the starter wire to the battery with no fuse.
I am having the same issue. Keep blowing the fuse on the fusible link. I would like to run the starter wire directly, although I am worried it is causing a short for a specific reason.
