Car wont start on cdi ignition system.
Im having an issue getting my car to fire. I am using 300m coils with a dynatek arc 2 cdi box. On stock coils I can get the car to fire. But as soon as I install the ignition system nothing. Ive checked the fuse, wiring, and verified that there is voltage to the box and still nothing. This is the first time ive dealt with an aftermarket ignition system so any help is appreciated.
if it runs fine on the normal setup then there are only 2 possibilities, 1. the install is faulty, or 2. the product is faulty. If you have verified that the install is correct then you should contact tech support for the product. They will probably have some troubleshooting procedures you can follow to try and further isolate the problem.
lancerrally45 (May 11, 2016)
is this relevant to OP's problem? its not like there aren't kits out there that use Dynatek CDI boxes on evo's wasted spark setup. Seems like you guys are giving OP grief for no reason.
Didier chacon (Nov 12, 2022)
Nomad4g63
Nov 3, 2013 06:27 AM
mrboost05
May 15, 2012 07:28 PM
Danieln
Oct 18, 2009 09:41 AM
SparkTech
68
Dec 31, 2008 05:40 AM
