Help a first time Evo owner out .
Greetings,
Purchased a one owner 2004 Evo 8 with 106 k miles. Car is stock at the moment but had a few questions.
Already ordered a few basic bolt ons. Car will be tuned on 93. Just curious on head gasket change and head studs are necessary to run on e85 on my higher mileage Evo.
The car has a slight grind going into third. It's very strange, only happens if you hold the shifter a certain firm way. WOT high rpm shifts shift like butter. Part throttle is where I'm having this issue. Already tried trans flush, and adjusted the clutch. Any other ideas?
Try looking at your shiftere bushings to see if they are worn out, stainless steel clutch line with the restrictor removal helped my shifting a lot also. I just did the redline cocktail transmission fluid change and my shifting improved a lot also. It feels a lot less notchy and no grinding at all. I used to experience some 5th gear grinding and not anymore. hope this helps.
Yea. Was hoping to be able to hit around 320-330 whp. And I have plenty of e85 stations around me. Just would hate to pay labor for head studs
Apexaholic
Mar 28, 2013 12:19 PM
Firehousemike
Mar 12, 2013 07:18 AM
anEVOx
Feb 28, 2011 12:33 AM
amper
Jan 25, 2010 07:15 AM
