Evo 8 bad ignition? Need new key / ignition?
I have a 2003 Evo 8, I am 90% sure my ignition is bad. The symptoms I am having are below.
- Wont crank over sometimes (but you hear the fuel pumps prime).
- Takes 5-15 tries turning the ignition on/off till it cranks/starts.
- I Checked the battery, starter, fuses, and took the steering columns off to zip tie the ignition plate and had 0 luck.
I cleaned my key (had a little bit of gunk / black stuff in the groves) it has been good since (6-8 tries).
I am thinking about going to the dealership and getting a whole new ignition / key set. They told me they have to sync the key and ignition together (has to be done at the dealership).
If my stock ECU has the immobilizer disabled do I need to sync the key / ignition still or can I just install it and turn the key?
Probably the ignition switch is bad which is a separate part from the key, immobilizer and tumbler assembly. Easy to replace and no need to go to the dealer.
https://www.evolutionm.net/forums/ev...ied-fixed.html
if your immobilizer is disabled than you should not need a chipped key programed from the dealer. you may need a scantool to see if the computer is getting a start signal from the key ignition. if you have an aftermarket alarm that can cause problems to. if you r gonna fix it yourself you will need a wirediagram and dvom at the least.
Let us know what the dealer finds.
My car was doing this but only on hot days. Since I installed a new ignition switch it has not reoccurred. Time will tell tho. I had a little movement as described above. I glued a paper shim around the bump-out where the screw goes. Still, it just could have been a bad switch - about 30 bux.
wait do not go to the dealer yet. I found a post on here not sure where at. it is somewhat common. check the white plastic piece that is on the ignition with one screw on It. sometimes it moves when the key is in the ignition and if its off centered at all even a little it will do what your talking about. just take out the screw and recenter it. make sure that your wires are not hanging with tension on them. its worth a try man. I read this last night and thought of you champion.
N33d4sp33d
Jul 20, 2012 03:06 PM
SmokinJoe
Dec 10, 2007 06:41 AM
