Evo 6 stutters
Old Sep 11, 2016 | 03:26 AM
rage mang's Avatar
Evo 6 stutters
My evo 6 developed a stuttering problem whenever i start off anywhere below 2.5k rpm power drops off and sounds like a subaru with burble in the exhaust note. checked all vacuum hoses intact. I have read that it might be a misfire is there a way to check before i limp the car to the shop? Car was running fine just last night.
Old Sep 11, 2016 | 11:29 AM
Ferp's Avatar
Do you have evoscan and a tactrix 2.0 cable? Can check with that. A lot of people can tell when they have a misfire just from the feel of the vehicle. You can check your spark plugs and see what kind of shape there in. Could also check the condition of your wires.
Old Sep 11, 2016 | 09:24 PM
rage mang's Avatar
I dont have a tactrix cable but i will take a look at the plugs n wires should i be on the look out for anything specific there like wire corrosion?
Old Sep 13, 2016 | 02:20 AM
rage mang's Avatar
Pulled the plugs out earlier and this is what 1 and 4 looked like pulled all of them out and will just go ahead and replace all
Old Sep 13, 2016 | 05:45 PM
Ferp's Avatar
Definitely look nasty. Hope the plugs solve your problem.
Old Sep 16, 2016 | 11:45 PM
rage mang's Avatar
Changed the spark plugs this morning and tho it smoothed the stuttering and the power band out its still stuttering especially under 2500rpm or whenever you just start off from 1st gear it even sounds like it has pops n bangs when u set off any other ideas? The idle is solid at 800 or so rpm and nothing is out of the ordinary other than the stutter when i get past the stutter the power and speed is still there and builds well but this stutter really bothers
Old Sep 17, 2016 | 12:05 AM
Ferp's Avatar
Do you have a wideband? Possibly still ignition issue. Check your wires, fuel pressure at the rail, check for any small vacuum and boost leaks.
Old Feb 2, 2017 | 10:22 PM
rage mang's Avatar
Update on the stutters got it diagnosed to a bad fuel filter its definetly more than a decade old so got that replaced and now were all good runs better than ever tho now i got fuel pump whine does a replacement walbro fix the whine?
Old Feb 3, 2017 | 11:45 AM
Ferp's Avatar
Walbros are loud. Look at a DW or Aeromotive fuel pump. Quieter and I've had much better luck with both of them over the Walbro products.
Old Feb 4, 2017 | 07:58 PM
rage mang's Avatar
Awesome thanks will look into those
4b11slayer
Oct 15, 2018 08:09 AM
Heirthos
May 13, 2017 01:49 AM
Evo47
Jan 31, 2016 07:56 PM
o2thag
Nov 10, 2007 06:56 PM
Eva01
10
Apr 10, 2006 12:29 PM
