Compression Results & Question
Old Dec 12, 2016 | 01:38 PM
barneyb's Avatar
As for injectors, flow testing which probably means sending them off, or replacing them all. Price would be the deciding factor here - or maybe not if a daily.
Old Dec 12, 2016 | 01:50 PM
AKB_EVO's Avatar
Even if I was to find that one of the injectors was faulty, I would still need a rebuild, right?
The evo will be daily driven in the spring/summer but not often in the winter.
Old Dec 12, 2016 | 07:30 PM
barneyb's Avatar
A rebuild depends on whether you think 150 is bad. Supposedly, stock compression is 163 with a service limit of 138. Anyway, I don't know if you have a higher compression build, a build up of carbon in the cylinders or a gauge a little out of calibration. I don't consider what you have as bad but that is me. I just wouldn't want it to get worse.
Old Dec 12, 2016 | 08:02 PM
AKB_EVO's Avatar
Yeah I will do another test just to be certain the gauge they were using wasnt a faulty one, just for the peace of mind.
I really appreciate all the help! Thank you!
jspecteggy
18
Mar 7, 2018 09:14 PM
dambikeracer
57
Mar 14, 2010 07:43 PM
05blue8
Apr 11, 2009 06:51 PM
Sloop
May 13, 2004 11:31 AM
zlancer
Lancer Engine Tech
17
Mar 5, 2003 01:14 AM
Quick Reply: Compression Results & Question
