Engine Removal Questions
So I will be pulling a motor for the first time without a lift on an Evo 5. Everytime I've had to pull an Evo motor I have had access to a lift, this time I will just be in a garage with jackstands. So normally I would bring the engine out from the bottom, but due to space constraints I will need to do this from the top instead. Any advice on how to do this? Should I leave the xcase in the car? Will I need to unbolt the axles? Is it possible to pull the motor and leave the trans in the car, or should I pull the motor with trans?
Thanks for any help. Did a few searches and couldn't find any guides, and most folks seem to drop it from the bottom.
6-speed
Sep 10, 2007 08:26 PM
Ink
12
Jul 25, 2006 06:59 AM
Racer RS X
Apr 17, 2004 07:28 AM
majestic lancer
Oct 13, 2003 07:02 PM
