oil restrictor size for BB turbos?
I believe the HKS turbo uses the stock oil line. I would call HKS to see what they recommend. It may be internally restricted, and/or designed to run on the stock feed line.
It is (was) supplied with it's own oil feed line. No restrictor in it that I could see.
I did call them (thanks for the suggestion) and they claim none needed.
Maybe it is internal to the casing, who knows.................
Reason I brought it up was I saw some talk here and there
about the reduced oil pressure required and found this
for the Garret BB turbos
http://www.streettunedmotorsports.co...or_fitting.htm
and some said not needed. I didn't get a banjo bolt with
all the supplied hardware (which as you know is virtually
every other piece needed to put in a turbo).
Got me concerned for a bit, as it seems that is
where the restrictor is located, many times, if one
is used.
XSivPSI
Dec 17, 2015 07:08 PM
XxBLACKMAMBAxX
Jan 27, 2005 11:08 AM
