No start then backfire
Old Mar 29, 2017 | 10:55 AM
Mackman's Avatar
It cranks but dont start right when I stop backfire..Car was drivable then one cold rainy try to start it and nothing then cranks then backfire any ideas..
Old Mar 31, 2017 | 08:15 PM
barneyb's Avatar
Since you say "cold rainy" then maybe https://www.evolutionm.net/forums/ev...s-how-fix.html
Old Apr 19, 2017 | 04:02 PM
supak1111's Avatar
did you suck up a bunch of water into your intake?
Old Apr 19, 2017 | 04:26 PM
kaj's Avatar
kaj
Sounds like a timing issue
Old Apr 19, 2017 | 04:32 PM
supak1111's Avatar
I would start with the basics... check that you have enough fuel pressure, bad pump could still push fuel but not build enough pressure and the car will not start. And make sure you have spark.
Seeing how its backfiring sounds like you may have too much fuel or not have spark all the time because of a bad sensor or for other issues could be causing this
Old Apr 19, 2017 | 09:04 PM
gixxer1621's Avatar
sounds like timing, when was the last time you had your timing belt done? take the upper timing cover off get engine on tdc check the timing marks, and wile you turn the engine inspect the timing belt
acct918
10
Mar 9, 2019 05:38 AM
Ekoy
AEM EMS
27
Mar 29, 2017 11:21 AM
STIU2SLO
Feb 14, 2017 03:21 AM
Motaz
Jan 14, 2005 05:27 PM
