Just blew my engine! Open to options / ideas what to do next 😂😂
TLDR: Everything is fine. Bad tune
you need to autopsy that engine. It might not be as bad as you think. Pull the valve cover and survey the damage, check the spark plugs, find where the oil is coming from.
Didn't continue making noises after the initial "pop" noise?
Did you make sure it didn't start leaking from the turbo feed line?
Yup! LICP came off lol
comoression test showed 161,161,161,157....so she is nice and healthy!!!
Silly me. I'd spent so much time installing the cams and everything else. Currently she is sitting on a trailer on her way to Buschur for the tune tomorrow morning!!!
glad to hear all is good, seen your stuff on Instagram and was looking forward to seeing numbers (jgreenwald) on insta. good luck looking forward to numbers
Could find no leaks, cleaned it up, it may have been residual from the cam install (having the valve off a bunch of times), or it could have been moisture/rain from the storms we had recently, and it had been parked outside for a few days...since the compression test was high I don't think the head gasket is busted, and I doubt I have any bent valves, but we shall see soon enough.....
Compression is too good to have bent valves. Bent valves would cause zero, or almost zero, compression.
Not returning to idle after load is indicative a vacuum leak, an issue with the TB, or the ISC motor.
