Need ideas to pass inspection
Hey guys, just bought an EVO 8 and need to get it pass inspection. Car has a Megan O2 housing and a magnaflow titanium exhaust. I need to get a catalytic converter on there somewhere.
I had an EVO 10 and I'm not familiar with 8/9's. Maybe cut and weld a cat into the downpipe? I don't want to hack up the exhaust because it's titanium. Maybe find a cheap aftermarket catback and weld a cat in that?
What is my best option?
is your high flow disguised to look normal? if not, how did u pass visual?
wjamyers (Apr 1, 2017)
This should take care of the “visual” . Are you sure the test pipe is titanium as well ? You can probably modify the below to be a bolt on and swap out temporarily. Another option is hack up the below cat shield and clamp it over the test pipe temporarily or fix it on permanently .
http://www.siliconeintakes.com/dsm-i...ter-p-320.html
you know you are in a state with inspection. you should get an oem full exhaust for swap out. look through FS, ebay, craigslist, im sure someone has an old exhaust to sell you.
here in VA they are moving to infrared sensors on the side of the road, measuring ACTUAL emissions. right now it's voluntary... who knows for how long.
http://potomaclocal.com/2015/12/08/s...-now-underway/
