⛔★ Evo 8 CEL not working, its not the bulb. Tephra v7 issue maybe?
Hey everyone, when I got my evo last year I'm pretty sure the Check Engine Light use to work. I was on stock 9417 software. Since than I've turned off a lot of CEL codes, like rear O2, and EGR and what not and I updated everything to Tephra V7. But now my CEL will not turn ON at all. Checked the bulb and its fine, I even switched it with one of the other bulbs that works for sure so its not the bulb.
Shouldn't the CEL come ON when you first turn the ignition to ON position like most of the lights? And than turn OFF once you start the car? Mine does not
Could Tephra v7 software update have anything to do with this issue? Can't find anything similar anywhere.
What i mean by burnt out is the actual connection in the instrument cluster, not the bulb itself.
How are you sure it isn't burnt out if it never comes on? When you turn the car on and the cel light doesn't pop up then it's most likely burnt out. If you really think it's tune related just load a stock rom onto the car for a minute. You wont even need to crank the motor, just set it to on.
And that isn't a bad idea! I'll try to find stock Evo 8 rom and try it just for a sec
supak1111 (May 29, 2017)
DarksideEng
Lancer Ralliart Vendor Classifieds
42
Apr 23, 2013 06:34 PM
DarksideEng
Lancer Vendor Classifieds
36
Aug 28, 2012 08:50 AM
DarksideEng
11
Aug 4, 2009 12:44 PM
DarksideEng
Aug 4, 2009 11:44 AM
DarksideEng
Jul 13, 2009 12:37 PM
