Gas Tank repair
Gas Tank repair
Hello EvoM members! I would like some input/advice on repairing or replacing my fuel tank. I finally got around to remove my fuel tank after I found out the previous owner broke a few studs on the fuel pump unit( Long story short he installed a "modded" walboro fuel pump, The unit was held in my one 8mm bolt and I guess he drilled and tapped where the studs used to be) It still leaks when I fill up the tank! After being quoted over $500 for new OEM tank I just don't think I could swing that at the moment, I was hoping to repair this one but I'm not even sure anymore... I was hoping someone on evom knows a shop that could properly repair this!i realize that every stud and bolt is rusted. Please take a look at the picture!
(Btw: I've garaged this car for the past 4 years, the previous owner lived in a condo in NY, so it's lived outside!)
Thanks in advance.
Thanks in advance.
Yes, there is a thread here on EvOM, where this repair was done. Ill search it, but you should as well
Someone may chime-in w/the link
EDIT: Heres one of them (see page 3): https://www.evolutionm.net/forums/ev...g-how-fix.html
Thanks! I'm gonna try this out this weekend !
ryukinevo
Nov 13, 2015 12:00 AM
