Hard to get my IX MR into first and reverse...clutch issue?
If it creeps the clutch is not completely disengaging. But why, dunno. I drove my stock clutch to 90K and the only symptom of a failed clutch was a slip in 5th gear at WOT. I recently had the transmission out and replaced the clutch disc again even though the one in it still looked like new so call that my third clutch and I have never had to adjust the clutch.
So maybe try bleeding and checking for brake fluid in the slave boot. if that doesn't help then maybe a new slave. A slave cylinder is petty easy to replace and bleed. One thing I noticed on the new looking clutch disc I replaced is that the springs were loose and rattled. Sometimes the springs come out and can get caught in the mechanism.
The trouble with diagnosing clutches is that the cause often doesn't become apparent until the parts are on the work bench.
Hey guys!
Just recently my 9 MR has been resisting going into first gear and reverse at a complete stop. Even with the car fully warmed up, it puts up more resistance than the normal "notchy" feel.
The first sign was that the car would ever so slightly inch forward when putting it into first gear (or inch backward in reverse). I'm talking an inch or possibly less. Probably not noticeable to anyone else but I have OCD issues.
I did a clutch pedal adjustment, in which it did help with a smoother clutch feel and shifting while moving. However, it's only at a complete stop that I'm noticing it resisting me. I did noticed when I go from second to first or second to reverse, it goes right in like butter etc.
My Evo has 78k miles on the stock clutch. No clutch slipping while driving or on WOT in higher RPMs. I haven't been driving the car for the last week because I don't want to possibly cause any harm. Is my clutch on its way out, or do I need to bleed the clutch/replace the master cylinder? Any help or insight is greatly appreciated!
Fireescape
Jul 4, 2016 11:18 PM
CaptainSquirts
10
Jul 15, 2015 11:51 AM
XK120
Dec 28, 2011 08:45 AM
