Evo 8 Dies When Turning Steering Wheel
Idle is set around 1100rpm
running S3 cams and head is fully built with GTX3582R turbo
every time I turn the wheel the car wants to die
is there a solution to this
I have had to play with a few idle tables and steps to prevent my car from dying coming to a redlight. Also may need to adjust ignition timing in those areas of the map. Are you tuning yourself or do you have a tuner you use?
My solution was probably to go with an electric power steering to prevent any more issues. Just trying to research what pump I need, connections, and power source
There is a little blue wire that comes off the power steering pump that steps up idle whenever you turn the wheel. Is it still connected? I don't think it's a game changer, but I would start there.
yea its still connected, just going to do an electronic power steering pump and self make a kit since buschur no longer sells them
You have a problem somewhere, no one ever just runs electric power steering for reasons like that.
Either tune related, or vaccum. Is it going lean?
What's the AFR and RPM at idle?
pulled the blue wire and the same-thing happened.
my guess its the connection somewhere in the car
TEXAS05EVO
Mitsubishi TC-SST Discussion
Aug 31, 2014 11:03 AM
jrainwater
Dec 30, 2013 02:39 PM
