6466 hp record on evo
Old Sep 20, 2019 | 02:44 PM
ineedboostman's Avatar
Anyone know what the record for the 6466 is? I've seen a few online searching around in the 900 range.
Old Sep 20, 2019 | 03:31 PM
LetsGetThisDone's Avatar
Like ~900 allllllll in on full bling builds. If you want ensure you hit 900-950, a 6870 is the better option.
Old Sep 20, 2019 | 06:03 PM
I was just wondering is anyone claimed they were. Doesn't sound like it. I dont want any more lag on my car. The 6466 should be enough unless I get bored of it. I was surprised when 700 didn't feel fast anymore so I'm not sure 800 will be that much different. Hope to get closer to 850
Old Sep 20, 2019 | 06:17 PM
The 6870 is realllyyyy close to the 6466 in spool up.
A proper setup will do 8-850 no problem. Ported head, Magnus intake, GSC S3 cams or similar, etc..
Old Sep 22, 2019 | 10:08 AM
Evo9_Dubai's Avatar
I'd expect it to be 500-650rpm laggier the very least.
The only car that I saw run crazy fast spool was on a ER 2.2L I believe and probably a twin scroll setup. ER did not want to dislose how they were able to achieve such fast spool. But maybe a quick spool valve? Who knows.
Old Sep 22, 2019 | 11:20 AM
Your expectation is simply incorrect.
No trickery from ER, that's how they spool up on a 2.2 with a twin scroll manifold.
A turbo that big should only be used in twin scroll config.
Old Sep 23, 2019 | 10:54 AM
If the 6466 maxed out doesn't scare the S*&T out of me them maybe I'll look into a 6870. That turbo on a 2.4LR would be nasty. I don't have Mivec they probably had they're modified Mivec head which also aids spool.
Old Sep 23, 2019 | 12:16 PM
Mivec would aid spool up on both turbos. The 6466 is a great turbo. But if you want it make 900, I suggest going bigger.
Spins_All_4
Sep 8, 2012 08:03 AM
500hpOnPumpEvo
May 30, 2008 12:13 PM
TOPPSEY
Feb 13, 2004 12:29 AM
Quick Reply: 6466 hp record on evo
