Evo 8 Passenger Side Fluid Leak
So Im having a leak on my passenger side and the fluid is somewhat clear (sometimes yellow-ish). At first i couldnt tell if it was brake fluid or powersteering. I took a closer look and i think its my axle, possibly loose. If it is loose, is it because its loose? or the seals are bad?
thank you. i found out that its my axle/axle seal. the axle doesnt lock into the inner shaft due to it not being a oem axle. hopefully when i replace the axle it stops leaking and not the seal.
