Map sensor
Map sensor
I have an 04 Evo 8 rs. I just recently did a boost leak test and fixed two major leaks one being the idle bleed flapper. And have noticed I am still leaking slight from my Omni 4 bar map sensor. I took it out and replaced the o ring but it is still leaking during boost test. Any suggestions?
Put a very small amount of sensor safe rtv around the o ring, have been doing this for years with no issues. idk why but i was in the same boat even after replacing the oring.
Otherwise people get a thicker ring.
https://www.evolutionm.net/forums/ev...ed-o-ring.html
CrazyIvan1978
Sep 30, 2018 05:39 AM
boosted91t
27
Jan 20, 2015 07:44 PM
