Abs and ayc lights flashing after installing aem Ems v2
Hello,
So I installed the ems v2 on my evo 8 with a new engine build, tuned it for the 1st break in startup... everything worked great expect my abs and Acd lights will not stop flashing as if its in Diagnostic mode, I took out the input cable out of the ems too see if that worked, did nothing... Checked if something is connected too the obd port but it was empty.
What can I do too make the abs and Acd lights to stop flashing??
Thanks 👍
Edit
Thanks 👍
Edit
found out the pinout for jdm Evo 7, that says 86 being vehical speed sensor and 87 being ayc/acd signal
And on ems v2 the pinout 86 is vehical speed sensor but the pinout 87 is throttle position switch and no ayc.
Please can
help me fix this as my abs and ayc lights are flashing under 20kms/hr.
Please can
FooM Anchoo
Feb 21, 2010 06:47 PM
