evo 7 no heat or ac blowing
Hi ,
i have an evo 7 and there is no heat or ac blowing through the car at all.
the center unit lights up when going through the settings on the module but nothing appears to be happening.
I checked one of the fuses on the kickpanel and it seems ok not sure what else it could be without replacing the heater blower assembly
If i understand your concern is that no air is coming out right? Could also be the resistor for the blower motor. You need a wiring diagram tho, cant help there. The one thing you can check without a wiring diagram is voltage at the blower motor. You can also apply direct power and ground to the blower motor and see if it works.
Hi ,
amsevokid
May 26, 2014 05:24 PM
