Acd + Ayc
ok now what's an open differential? how is it different from the limited slip differential?
if your stuck in mud...an open diff will spin the wheel which has the least amount of resistance, power will be directed to the wheel with the elast amount or resistance. A limited slip will force power to the both wheels equally or "lock up" with tension springs inside.
Originally Posted by 1QWKEVO
as the USDM evo sits it handles 90 degree turns fine stock... again if you know how to control the vehicle. I personally would liek to have both the ACD and AYC on my car just for the state of mind of them being on there, daily driving you won't notice anytihng really other then the car may pull for feel like its pulling slightly harder becasue of the torque split. AYC would be great to have just as a safety device, I mean the car would be much safer in rain and troublesome situations.
You can add all these devices to the USDM but it is very costly, actually i'm not sure if the AYC is possible but i know the ACD has be transplanted, your better off selling your current model and buying a new model which already has them.
PS the USDM only has one mechanical diff, rear. The front is open on the evolution VIII. The RS is said to have front and rear mechanical diffs.
Originally Posted by mprtklr
rather than to explain what it is, ill illustrate, ill let someone else explain technically.
ok when you mean spin the wheel with the least resistance, doesn't that mean that the wheel has the least friction? then wouldn't that cause the wheel to just spin more than gain any traction??
El Jefe
ok guys... lol i'm really confused here.. correct me if i'm wrong ( because i most likely am ).. but i thought our evos redirect power to the tires that have the most grip??? idk.. but after reading this thread i have been totally confused... ... i just wanna know what OUR evos can do and the handling situation on them... like what does what exactly.... if anyone can answer that in full that would be great.
Originally Posted by zstryder
The MR hasn't been officially announced yet.
http://media.mitsubishicars.com/deta...82696&mime=JPG
The AYC diff is not strong enough to come to the american market. And not to mention the added cost involved.
The ACD is strong enough though. Most of the maintenace costs are due to the ayc anyway, acd is pretty much self maintaining (just your normal gear oil changes).
the differential in the front is open. so power being sent to the front will go via path of least resistance to either the left or right. the center is a viscous coupling...like a limited slip diff. the power will be forced to the front or back based on which SIDE (front/back) has more resistance (grip). the rear is a limited slip, so it will act the same as the center.
God, someone kill me now.
That is not a press release. Until we see a press release, it is not "official" in any way.
