Clifford allarm
Clifford allarm
Hey guys I have a turbo timer on my car and I just bought the New 2.5 matrix clifford alarm system do u think when I set the alarm and take out the key so the turbo timer works will cause any problems. I heard the alarm kills ure ignition switch and I dont want that to be an issue when setting the alarm the car shuts off instead of cooling down before shutting off...any suggestions??....
I had a Ungo alarm on my Eclipse with a GReddy turbo timer, I used to get out, lock the doors let the turbo timer do its thing, then after the engine shut off, the alarm would arm in 30 secs. But the doors were locked already so no one could get in within the 30 secs.....
Worked great for me. Just do some tests on it in your drive way and see..........
i just had a new Python alarm installed in my evo after i was informed that most of the clifford, python etc alarms have a built in turbo timer that can be used and if you really want to use your turbotimer, it is possible to integrate it into your alarm as i am going to do with mine.
